- To:
- Subject: Re: [cgal-discuss] Fill hole of a horseshoe shaped mesh (concave)
- Date: Fri, 14 Dec 2018 15:41:38 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I don't understand what you mean. If you have a hole in a mesh
how can the order of the vertices be different from the order along
the cycle of border halfedges?
I might be missing something. Could you give more details?
On 12/14/2018 01:48 PM, aseverino wrote:
I got it working, thanks.
I would like to suggest that the developers add a variation of
triangulate_hole_polyline that uses the vertices instead of the points, so
you can close a hole on a mesh by explicitly telling the vertices and the
order the edges should be formed.
- [cgal-discuss] Fill hole of a horseshoe shaped mesh (concave), aseverino, 12/10/2018
- Re: [cgal-discuss] Fill hole of a horseshoe shaped mesh (concave), Sebastien Loriot (GeometryFactory), 12/12/2018
- Re: [cgal-discuss] Fill hole of a horseshoe shaped mesh (concave), aseverino, 12/14/2018
- Re: [cgal-discuss] Fill hole of a horseshoe shaped mesh (concave), Sebastien Loriot (GeometryFactory), 12/14/2018
