cgal-discuss - [cgal-discuss] Area of polygon obtained with alpha_shape_2
  • To:
  • Subject: [cgal-discuss] Area of polygon obtained with alpha_shape_2
  • Date: Tue, 18 Dec 2018 11:52:37 -0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I used CGAL's alpha_shape_2 in REGULARIZED mode to get outline of set of points. I want to calculate area of the resultant shape. I tried to make a Polygon_2 from vertices obtained with Alpha_shape_vertices_iterator but it seems like the points are not ordered because is_simple for the polygon returned wrong. Segments obtained with Alpha_shape_edges_iterator are not ordered/connected as well. is_simple is important because area is ill defined without it.
Can someone share his experience with finding area of polygon obtained with alpha_shape_2?
