- To:
- Subject: Re: [cgal-discuss] AABB trees with faces from several surface meshes
- Date: Wed, 19 Dec 2018 10:25:47 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thank you, Andreas.
I've already read that page and in fact my code is using OneFaceGraphPerTree set to CGAL::Tag_false. However, the primitive ID is still a plain face index. The class CGAL::SM_Face_index does not seem to have a way of referencing the surface mesh where that face comes from. Am I missing something?
Hello,
Please have a look at
https://doc.cgal.org/latest/AABB_tree/classCGAL_1_1AABB__face__graph__triangle__primitive.html
OneFaceGraphPerTreeis either
CGAL::Tag_true
orCGAL::Tag_false
. In the former case, we guarantee that all the primitives will be from a commonFaceGraph
and some data will be factorized so that the size of the primitive is reduced. In the latter case, the primitives can be from different graphs and extra storage is required in the primitives. The default isCGAL::Tag_true
Best,
Andreas
On 12/19/2018 2:00 PM, Lucio Santi wrote:
Hello,
I have an AABB tree storing triangular faces coming from different surface mesh instances. I'm using that data structure to compute intersections with rays, but currently the primitive ID that I obtain for each intersection query is just a face index (i.e., an instance of CGAL::Surface_mesh<Point_3>::Face_index). I would like to know which surface mesh this face belongs to. Is there a clean way to do this? I was thinking of providing my own AABB primitive somehow, but I'm not sure if this is the proper way to do it (and in fact I'm not even sure how this can be done).
Thanks in advance for your help,
Lucio-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] AABB trees with faces from several surface meshes, Lucio Santi, 12/19/2018
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, Andreas Fabri, 12/19/2018
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, Lucio Santi, 12/19/2018
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, Sebastien Loriot (GeometryFactory), 12/19/2018
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, lsanti, 12/20/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, Pierre Alliez, 12/26/2018
- Re: [cgal-discuss] AABB trees with faces from several surface meshes, Sebastien Loriot (GeometryFactory), 12/31/2018
