- To:
- Subject: Re: [cgal-discuss] Keeping mesh labels during union (ref. 7/25/2018)
- Date: Tue, 1 Jan 2019 18:55:35 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Sebastien:
Thank you.
Understood wrt not having attributes in "your" off files; by inspection.
I would like to use material ids in "downstream" analyses; e.g., meshing.
For simple cases, identifying intersections manually works. So I can use off
files
to build mesh files with attributes in other formats; e.g. vtp.
I will perhaps need intersections for rather complicated multiple material
structures
(many intersections). Do you have any guidance as to how i might print out
attributes
(associated with faces) to some file.
I am used to writing mesh file format converters, so the format doesn't
matter.
Regards,
Tim
- Re: [cgal-discuss] Keeping mesh labels during union (ref. 7/25/2018), Dr01TSPC, 01/02/2019
