- To:
- Subject: [cgal-discuss] CDT mesh refinement in multiple domains
- Date: Wed, 6 Feb 2019 11:18:28 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:xkwUUxcD1/g1fQDQsu+mrJvTlGMj4u6mDksu8pMizoh2WeGdxcu6YB7h7PlgxGXEQZ/co6odzbaO4+a4ASQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTahYr5+Ngm6oRnMvcQKnIVuLbo8xAHUqXVSYeRWwm1oJVOXnxni48q74YBu/SdNtf8/7sBMSar1cbg2QrxeFzQmLns65Nb3uhnZTAuA/WUTX2MLmRdVGQfF7RX6XpDssivms+d2xSeXMdHqQb0yRD+v6bpgRh31hycdLzM3/mHZhNJzgqxGrx2uuxNxzpXIYIyXKPZyYr/Rcc8ESWdHQ81fVzZBAoS5b4YXDOoBPONYr4j+p1QUsBCzAgmtBOLgyz9VnHD227c20+AgEQzdxwwvAcgBsHvOo9XpKqgeS/y6zK7NzTjaaf5dxDnz6I/Nch87oPGMW6p9cczLxkY0DAzFikufpZb5MDOS0+QAtXWQ4el4Ve+3lmIqrwV8riKhy8ovkIXEhYMYxkrF+Ch4xos+OMe2R1RhYdG+FZtdryGaOJVyQsMlW2xovik3xqcAuZGhZycF05AnyADFZ/ObdIiI5wrvVOeXIThmmHJoYK+zihK2/ES6xODxVdO43VVLoyZfk9TBt2gB1xnJ5ciGTvt98F2h2TGK1w3L6uBEIE81lbfBJJ4n2LIwkpsTvF/YHiDogkr2g7WZdlk69eSy9+vnZbDmqoeGN4BokgH+LrgumsunDOskPQgBRWyb9f2h273i5k32XKhKjuYtkqTCq5DbJcEbprajDANP04Yj7Qy/Dza839gCk3kHNgENRBXShIfgPxTCIevzEOykq1WqijZigf7cbZP7BZCYLXnGkbToNeJs6l5BwQx1ydF3/J9dBbgdLbT4XUqn54+QNQMwLwHhm7WvM956zI5LATveUJ/cC7vbtBqz3sxqJuCNYIEPvzOkcKo+6vfhhGM031QaePvyhMdFWDWDBv1jZn6hTz/0mN5YSjURswMxRfDnzlaFVGwLPivgb+cH/jg+TbmeI8LDS4Sq2eHT2nv9GJRcbGRLTFuLFCWxeg==
Hi,
I am trying to perform CDT mesh refinement in multiple domains. I have
the following questions.
1) can you create CDT using edge swaps rather than point insertion
2) can you perform an oriented walk to find triangle containing point to be
inserted, which does not cross a constrained edge (i.e., either returns
triangle & constrained edge that would have been crossed OR the containing
triangle)
3) can you keep constrained edges from being swapped when mesh is refined
4) can you define an element handle/type/etc that is passed onto the new
elements when they are refined
Thanks for your help!
- [cgal-discuss] CDT mesh refinement in multiple domains, kimika, 02/06/2019
