cgal-discuss - Re: [cgal-discuss] What means "_idx < data.size()"
  • To:
  • Subject: Re: [cgal-discuss] What means "_idx < data.size()"
  • Date: Thu, 7 Feb 2019 16:33:06 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
How can I reproduce the error?
Diificult, the code is in white_dune ( https://wdune.ourproject.org )
https://wdune.ourproject.org/docs/usage_docs/dune_en.html#boolean
Sorry. I found out, that the error is in the triangulation/optimize code
of white_dune before i call
CGAL::Polygon_mesh_processing::corefine_and_compute_union().
I used
ftp://ftp.ourproject.org/pub/wdune/meshUnionTest.cpp
and
ftp://ftp.ourproject.org/pub/wdune/in_1.off
ftp://ftp.ourproject.org/pub/wdune/in_2.off
$ g++ meshUnionTest.cpp -lCGAL -lmpfr -lgmp
$ ./a.out
it_poly_hedge!=edge_to_hedge.end()
But the exeption is different 8-(
If i use (IndexedFace)Set->triangluate in white_dune and write the off
files again, it works.
so long
MUFTI
