Re: [cgal-discuss] How to use CGAL connected_components function to convert one surface mesh into many?
- To:
- Subject: Re: [cgal-discuss] How to use CGAL connected_components function to convert one surface mesh into many?
- Date: Mon, 11 Feb 2019 10:44:37 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
SO cross-post (already answered):
https://stackoverflow.com/questions/54609105/cgal-how-to-use-cgalpolygon-mesh-processingconnected-components-to-convert
Sebastien.
On 02/11/2019 10:33 AM, Silberklinge wrote:
I have a function that requires a CGAL::Surface_mesh object as input and
returns a std::vector<CGAL::Surface_mesh> as output, where each element in
the output is a connected component of the input. I am aware that there are
functions for calculating connected components in CGAL, but these just
mutate the existing mesh object in some way by removing/labeling the
relevant faces. I need to construct a new CGAL::Surface_mesh object for each
connected component in the input CGAL::Surface_mesh object. How do I
accomplish that?
- [cgal-discuss] How to use CGAL connected_components function to convert one surface mesh into many?, Silberklinge, 02/11/2019
- Re: [cgal-discuss] How to use CGAL connected_components function to convert one surface mesh into many?, Sebastien Loriot (GeometryFactory), 02/11/2019
- Re: [cgal-discuss] How to use CGAL connected_components function to convert one surface mesh into many?, Silberklinge, 02/11/2019
