[cgal-discuss] How to create a Surface_mesh from Surface_mesh_default_triangulation_3 and a vector of points?
- To:
- Subject: [cgal-discuss] How to create a Surface_mesh from Surface_mesh_default_triangulation_3 and a vector of points?
- Date: Tue, 12 Feb 2019 18:07:15 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
- Openpgp: preference=signencrypt
I tried this but failed
typedef CGAL::Surface_mesh_default_triangulation_3 Triangulation;
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Point_3<Kernel> Point;
int main()
Triangulation tr;
std::vector<Point> points;
//how do I create Surface_mesh from points?
tr.insert(points); //does sadly not work
Surface_mesh mesh = tr.createMeshFromPoints(points);
- [cgal-discuss] How to create a Surface_mesh from Surface_mesh_default_triangulation_3 and a vector of points?, Rash, 02/12/2019
