Re: [cgal-discuss] retrieve associated information with halfspaces after a halfspace intersection
- To:
- Subject: Re: [cgal-discuss] retrieve associated information with halfspaces after a halfspace intersection
- Date: Fri, 22 Feb 2019 09:49:45 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
With the current code there is no entry in the API. However it should not be not hard to do it. Indeed, looking at the halfspace_intersection_with_constructions_3.h for example, you'll see
that when a new face is created in build_dual_polyhedron (which is building the dual of the dual, i.e. the final intersection) we iterate
over vertices of the convex hull of the dual (one vertex = one plane)
so we could add a property in the API to add that information.
Best regards,
Sebastien.
On 2/22/19 8:19 AM, Maarten Moesen wrote:
Dear CGAL community,
From a large vector of planes (halfspaces), in which each plane has some information attached, I’d like to create a convex polyhedron using
CGAL::halfspace_intersection_3() and halfspace_intersection_with_constructions_3().
How can I efficiently identify in the resulting polyhedron which planes where selected, so that I can efficiently retrieve the information associated to each selected plane?
Best regards,
Maarten
Maarten Moesen, PHD
Polymer Physicist Computational Modeling
HUNTSMAN (Europe) BVBA
Everslaan 45
B-3078 Everberg
Belgium
VAT: BE - 0468.807.829
Office Phone: 0032 (0) 2 758 9962
- [cgal-discuss] retrieve associated information with halfspaces after a halfspace intersection, Maarten Moesen, 02/22/2019
- Re: [cgal-discuss] retrieve associated information with halfspaces after a halfspace intersection, Sebastien Loriot (GeometryFactory), 02/22/2019
- RE: [cgal-discuss] [EXTERNAL] Re: retrieve associated information with halfspaces after a halfspace intersection, Maarten Moesen, 02/22/2019
- Re: [cgal-discuss] [EXTERNAL] Re: retrieve associated information with halfspaces after a halfspace intersection, Sebastien Loriot (GeometryFactory), 02/22/2019
