Re: [cgal-discuss] Example use of circulator to collect all cells around an edge?
- To:
- Subject: Re: [cgal-discuss] Example use of circulator to collect all cells around an edge?
- Date: Mon, 25 Feb 2019 08:50:15 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi Adam, states: typedef Triangulation_data_structure::Edge Edge and when you loo at the concept https://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html you find: typedef Triple< Cell_handle, int, int > Edge Best, Andreas
On 2/25/2019 5:58 AM, Adam Getchell
wrote:
Hello all,
If I want to collect cells incident to a vertex in
a Triangulation into a container, I use `OutputIterator
CGAL::Triangulation_3<Traits, TDS, SLDS>::incident cells`,
passing in the Vertex_handle of the vertex and an OutputIterator
(e.g., std::back_inserter) to the container of collected cells,
e.g.:
tds().incident_cells(Vertex_handle,
std::back_inserter(cells)
From looking at the documentation:
https://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#a0741a861a6291131384529349cb994a4
I’m not clear how to do the same for the cells
around an edge.
It looks like `Cell_circulator
SLDS>::incident_cells(Edge e, Cell_handle start) const` would
give me a circulator of the cells incident to the edge, but I’m
not able to resolve to the correct overload of the
incident_cells() function.
I’m passing in for the Edge argument an Edge_handle:
using Edge_handle = std::tuple<Cell_handle, int,
int>
Which describes the edge according to a cell and two
vertices in the cell which comprise the Edge. On that logic,
then, I’m using `incident_cells(Edge_handle e,
std::get<0>(Edge_handle)` to pass in the Edge and starting
Cell, but this is not resolving.
Is there an example of how to obtain a
Cell_circulator of the incident cells to an edge?
Thanks for your attention,
Adam
Adam
Getchell
https://keybase.io/adamgetchell -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri |
- [cgal-discuss] Example use of circulator to collect all cells around an edge?, Adam Getchell, 02/25/2019
- Re: [cgal-discuss] Example use of circulator to collect all cells around an edge?, Andreas Fabri, 02/25/2019
