- To:
- Subject: Re: [cgal-discuss] Convert Polyhedron_3 Vertex_handles to integers
- Date: Tue, 26 Feb 2019 08:15:59 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:5CwnKBf9YMx9QunM7R62spcPlGMj4u6mDksu8pMizoh2WeGdxcS5YR7h7PlgxGXEQZ/co6odzbaO4+a4ASQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTahYr5+Ngm6oRnMvcQKnIVuLbo8xAHUqXVSYeRWwm1oJVOXnxni48q74YBu/SdNtf8/7sBMSar1cbg2QrxeFzQmLns65Nb3uhnZTAuA/WUTX2MLmRdVGQfF7RX6XpDssivms+d2xSeXMdHqQb0yRD+v6bpgRh31hycdLzM37X/ZisJwgqxYrhyuqRNwzIzIb4yOLvVyYrnQcMkGSWdPXMtcUTFKDIOmb4sICuoMJfpVr4/gqFsUsxSxHxKsD/7vxDBSnXD2x6w62PkmHA7c2gwvAsgOv2rOo9XuLqsSX/q6w7LSzTXCdP5W1iny6I/Nch8/vfGMR7JxccTLxkYzCwPFiU+QqIz/MzyJ0eQNtnGW4ux9XuyhjG4nrht+ojmpxso0lobJiZgaylTe+SV+2oY1Ktu1Q1N4b968CJZduCCXO5FrTs8+Q2xkoik3x7IctZKmeCUHyowrywDFZ/Cac4WE+B3uWPiLLTtlhH9pZbSyjAuo/0e60O3zTMy03U5KriVbltnMsWgA2hLJ5siCTftx40Ws1DWV2wDW8O5EIEQ0mbPcK5483r48jJ0TsVrDHiPsnkX5krOWel0l+uiu9evnfq3rq5CdOoNulw3yLqQjltawDOk3KAQCQmyW9Oak2L3m50L5QbFKjvMskqnetZDXPd4UpqikDA9PzIks8Q2/Ay2o0NsChnYHNlNFdQmIj4f3PFHOJe73Deulg1Wsnjdk3ezJPqHmApXXLnnPiqvufbF460JE0go80chf545ICrEGOP/8RkDxu8bcDhMgLgO0wv3nB8lg1oMFQmKCGbSZMaPXsV+Q/O0jOeiMZIkPuDb8Mfcp/fDujWVq0WMaKKKm1J9SZHGjFel9OG2YZ2Dti5EPCzQkpA07GcXshEePWCUbSX+4RaN0sjg9BJirBJyFSImnmr2p0yq8G5BKfHFIA1uQFm35MY6DXqFfO2qpPsZ9n2lcBvCaQIg72ET27V6o+/9cNuPRvxYgm9fm3dlx6ffUkEtrpzN5CMGQz3ucQWh/gmQSVnk926Ut+RUhmGfG6rBxhrljLfIW/+lACF5oOpPbyuFmEcH8Uwndec2YDl2hR4f+WGxjfpcK29YLJn1FNZCigxTEhXT4WPkQkOXUVNox+6PYmn/sO4B61XaA0qQ93QEr
Hello, On what do you want to apply std::distance ? You can add an int field to vertices as described here: https://doc.cgal.org/latest/Polyhedron/index.html#title12 You might switch to Surface_mesh
https://doc.cgal.org/latest/Surface_mesh/index.html Andreas On 2/26/2019 5:50 AM, Robert Sage
wrote:
Hello,
We need to convert Polyhedron_3 facet vertices from
Vertex_handle to integer ids exactly like I see in:
https://doc.cgal.org/latest/Polyhedron/Polyhedron_2polyhedron_prog_off_8cpp-example.html
So we have adapted this code but are observing each
std::distance operation runs at O(n) and thus the whole
conversion takes a long time for Polyhedron with many
facets. Is there a more efficient way?
Thank you!
Robert
-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri |
- [cgal-discuss] Convert Polyhedron_3 Vertex_handles to integers, Robert Sage, 02/26/2019
- Re: [cgal-discuss] Convert Polyhedron_3 Vertex_handles to integers, Andreas Fabri, 02/26/2019
- Re: [cgal-discuss] Convert Polyhedron_3 Vertex_handles to integers, Sebastien Loriot (GeometryFactory), 02/26/2019
