- To:
- Subject: [cgal-discuss] CGAL 2D Triangulation: Get only inner triangles
- Date: Sun, 3 Mar 2019 05:16:55 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I am using CGAL 4.13 to do some 2D triangulation of an outline (I am also a
total CGAL beginner). In my case some random data originally read from
GeoJSON:
<http://cgal-discuss.949826.n4.nabble.com/file/t376086/hfx5w.png>
The triangulation is done exactly like mentioned in the CGAL user manual:
https://doc.cgal.org/latest/Mesh_2/index.html#title14
But when I fetch the triangles out of the *Mesher* (via
*mesher.triangulation()*), is do not only get the inner triangles but also
some "outer" triangles:
<http://cgal-discuss.949826.n4.nabble.com/file/t376086/FJqnh.png>
Is there a way to get only the triangles matching to the original outlines?
Like this:
<http://cgal-discuss.949826.n4.nabble.com/file/t376086/X6l4p.png>
Could you please guide me to some functionality in order to drop these
non-required triangles? Or am I using the completely wrong technique?
Thank you in advance.
Thomas
- [cgal-discuss] CGAL 2D Triangulation: Get only inner triangles, einherjer, 03/03/2019
- Re: [cgal-discuss] CGAL 2D Triangulation: Get only inner triangles, Andreas Fabri, 03/04/2019
- Re: [cgal-discuss] CGAL 2D Triangulation: Get only inner triangles, einherjer, 03/05/2019
