cgal-discuss - [cgal-discuss] CGAL installation no ALL_BUILD.exe Windows
  • To:
  • Subject: [cgal-discuss] CGAL installation no ALL_BUILD.exe Windows
  • Date: Thu, 14 Mar 2019 14:45:08 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi there guys I'm trying to install CGAL4.13. When I use cmake to create CGAL.sln file the configuration says is done, and I do generated afterwards. However I do see that it says that I'm missing a couple of stuff:
1)Qt5OpenGL Qt5Svg Qt5 cannot be configured
2)ZLIB_LIBRARY ZLIB_INCLUDE_DIR
However cmake does generate the CGAL.sln, I do build them and they don't give any errors. But when I try to run them, I have the following message: Unable to start program: C:\dev\CGAL-4.13\build\Debug\ALL_BUILD can't be found. I've tried everything I still have the same error. Can you please help? Thank you for your time. Adrian
  • [cgal-discuss] CGAL installation no ALL_BUILD.exe Windows, Adrián Briceño Aguilar, 03/14/2019
