- To:
- Subject: Re: [cgal-discuss] Alternative to Shewchuk's triangle
- Date: Wed, 20 Mar 2019 17:04:24 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23: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
Thanks, I'll check that.
Motivation: Mapping to a given boundary that can't change. Generating the
map usually involves discretizing the interior, i.e. a triangulation without
Steiner points on the boundary.
An example:
[Weber14 "Locally Injective Parametrization with Arbitrary Fixed
Boundaries"]
In Fig. 16, the mesh is cut and mapped to a non-convex (planar polygonal)
boundary. If I want to triangulate (remesh) this polygon and glue it back to
a surface, the twin seam edges need to correspond. Adding Steiner points
haphazardly on them may compromise that.
A 3D example:
[Levi15 "Smooth Rotation Enhanced As-Rigid-As-Possible Mesh Animation"]
In Fig. 1, the 4th cylinder is a surface deformation done with discretizing
the interior and deforming the tets. This without changing the given
surface. TetGen was used for the task instead of CGAL for a similar reason.
- [cgal-discuss] Alternative to Shewchuk's triangle, Zohar, 03/18/2019
- Re: [cgal-discuss] Alternative to Shewchuk's triangle, Marsh, Chris, 03/18/2019
- Re: [cgal-discuss] Alternative to Shewchuk's triangle, Laurent Rineau (CGAL/GeometryFactory), 03/18/2019
- Re: [cgal-discuss] Alternative to Shewchuk's triangle, Zohar, 03/20/2019
