- To:
- Subject: Re: [cgal-discuss] Partition a 2D polygon - extract graph faces
- Date: Thu, 4 Apr 2019 16:24:13 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23: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
That works nicely, thanks.
Would it work with CGAL::optimal_convex_partition_2 as well?
- Re: [cgal-discuss] Partition a 2D polygon - extract graph faces, Andreas Fabri, 04/02/2019
- Re: [cgal-discuss] Partition a 2D polygon - extract graph faces, Zohar, 04/04/2019
- Re: [cgal-discuss] Partition a 2D polygon - extract graph faces, Andreas Fabri, 04/05/2019
- Re: [cgal-discuss] Partition a 2D polygon - extract graph faces, Zohar, 04/05/2019
- Re: [cgal-discuss] Partition a 2D polygon - extract graph faces, Andreas Fabri, 04/11/2019
