cgal-discuss - Re: [cgal-discuss] Mesh_estimation example doesn't work correctly
  • To:
  • Subject: Re: [cgal-discuss] Mesh_estimation example doesn't work correctly
  • Date: Fri, 17 May 2019 09:06:14 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
After some more trying around I figured out that I just had to replace
162 if_name_string = "data/ellipe0.003.off";
with
162 if_name_string = "C:/ Full path to /data/ellipe0.003.off";
and it worked correctly.
