cgal-discuss - Re: [cgal-discuss] Question about 2D Visibility
  • To:
  • Subject: Re: [cgal-discuss] Question about 2D Visibility
  • Date: Fri, 24 May 2019 02:35:20 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thanks for your reply.
I noticed the example which you gave. But this example applies to simple
polygon, not for the polygon with holes. The following example shows the 2D
visibility of the boundary point of the polygon with holes, not for the
inside point. Could you show me how to use this code to do that, please?
Thank you.
https://doc.cgal.org/latest/Visibility_2/Visibility_2_2general_polygon_example_8cpp-example.html
Best regards,
Andy Li
