cgal-discuss - Re: [cgal-discuss] Compilation error on poisson reconstruction example
  • To:
  • Subject: Re: [cgal-discuss] Compilation error on poisson reconstruction example
  • Date: Wed, 5 Jun 2019 13:01:51 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Yes, or use the older example:
https://doc.cgal.org/4.11.3/Poisson_surface_reconstruction_3/Poisson_surface_reconstruction_3_2poisson_reconstruction_function_8cpp-example.html
Note the compatibility is backward, so examples from older release
should compile with new versions of CGAL but new examples shall not
necessarily compile with older release.
Sebastien.
On 6/5/19 11:50 AM, Nidaime wrote:
I am currently using the 4.11-2 CGAL version.
I can see that the latest version is 4.14, should I try to install a newer
version of CGAL ?
