- To: "" <>
- Subject: Re: [cgal-discuss] Templates and combinatorial maps
- Date: Thu, 13 Jun 2019 09:25:32 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:FCJjxxNbGacFov58Sg4l6mtUPXoX/o7sNwtQ0KIMzox0I//5rarrMEGX3/hxlliBBdydt6sdzbOL4+u5ADxIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfK5+IA+roQjRtcQajpZuJrsyxxDUvnZGZuNayH9yK1mOhRj8/MCw/JBi8yRUpf0s8tNLXLv5caolU7FWFSwqPG8p6sLlsxnDVhaP6WAHUmoKiBpIAhPK4w/8U5zsryb1rOt92C2dPc3rUbA5XCmp4ql3RBP0jioMKjg0+3zVhMNtlqJWuBKvqQFhzY7aY4+bOvRxcazfctwGXmdBUdpdWjZdD4+gYYYCD+wMNvtYoYnnoFsOqAOzCwixBOPuzj9IgmX53bA/0+s/DArI0hYvH9cPsHvOqtX6KboZXOe6zKnVzDXDa/dW1i3g6IjNbB8tu+yDUqh1ccrQ00YvER7Kg06UqYzkJTOV1/8Nv3KH4OpmT+KvkHQrqw9rojW2wMonl4fHhoUQyl/e9CV5xp44KsG+SE5het6oCpVQtzucOoBrQc0iW3lltDs0x7AJo5K3YjUGxZs9yxLCaPGKcJKE7g/sWeuQOTt0mm5pdK6iixu38EWty/HwW8y03VpWsiZJj9zBum0C2hDN78WKS/9w80m91juKyw/f9PxLLEIxmKbGN5Eu2KI8m58XvEvZBCD7m0P7h7KMeEo+4Oin8eHnb63mppCCM490jRnzPbgvmsykG+Q4KQ0OX3SD+eimyb3j+0z5QKtTgv0ykqjZt5baKdkBqq63GQ9Zyocj6xChADe6yNkUgHcKIV1fdB6ZkoTkNEvCLO37APq8mVigjThmyvHeMr3kGJrNL3zDkLn7fbZ67k5R0AUzzc1e55JQDrEOOu/zWkrvu9DCExA2KQm0w+f9B9V7y4wTQmaPAq6DMKPTql+E/P4gI++WZI8Oojr9JeIl6+b0jXAlgV8dYbWp3ZwPZX+kEfRpOUGZbWPxjdcACmcFohc+TPfxiFCZSj5SZ3OyX7om6T0hCYKmC53DRoG3j7Cb0ie7BM4eWmcTQFuDGHOte4SfUOoXcwqTJNVgm3oKT/LpH4Qu3BXruA7hwKd8NcLV/DcZvNTtzo4myffUkEQd6D1wC82A1mzFY2hxn2oOS3di071+pUh011KOl6Rxhv1RE9B74/JTUxx8PpjG1Kp0EYahCUr6Yt6VRQP+EZ2dCjYrQ4dpmoJcUwNGA9ynyyv78W+qDrsSzeDZD50v6LnZw2C3OsB81TPCxa4n1h8oWJkXbDz0tutE7wHWQrXxvQCcnqeue74b2XeQpmOC12uV+kpeShU2X7+XBClDNHuTlszw4wb5d5HrEa4ua1YTzc+YK7AMYdvzlhNIXqW7NQ==
Hi Yan;
Le 12/06/2019 à 11:31, Yan Garito a
écrit :
Hello,
I'm having some trouble using combinatorial maps alongside
templates. Here's the situation: I have a class A that contains
a combinatorial map as an attribute and I want to template A by
a number type, which is the information I want the edges of the
combinatorial map to store. However, this results in compiler
errors when trying to iterate over the attributes. Untemplating
and hard coding the number type "fixes" the problem.
See the attached files for a minimum example of the problem.
My compiler is g++, and my OS is Ubuntu 18. I did not tweak the
Makefile generated with the CGAL scripts.
The errors comes from a "strange" C++ rule. When you call a
template method in a template class, you need to use the keyword
template.
In your minimal example, you should write:
for (Edge_attrib_iterator
it = cm.template attributes<1>().begin(),
itend = cm.template attributes<1>().end(); it
!= itend; ++it)
std::cout<< cm.template
info_of_attribute<1>(it) <<"; ";
Best
Guillaume
Thank you in advance,
Yan Garito,
First year DIT student at ENS Rennes
-- =================================================================== Guillaume DAMIAND CNRS - LIRIS UMR 5205 Université Claude Bernard Bâtiment Nautibus (710) 43 Boulevard du 11 Novembre 1918 69622 Villeurbanne Cedex (France) ------------------------------------------------------------------- Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36 Mail: Web: http://liris.cnrs.fr/guillaume.damiand/ ===================================================================
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Templates and combinatorial maps, Yan Garito, 06/12/2019
- Re: [cgal-discuss] Templates and combinatorial maps, Guillaume Damiand, 06/13/2019
