Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram
- To:
- Subject: Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram
- Date: Tue, 18 Jun 2019 15:03:51 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
This doesn't change much: although at that point in time, weighted_point_3 was indeed not part of the kernel, the regular triangulation had the same parameters as it still does: template < class Gt, class Tds_ = Default, class
Lock_data_structure_ = Default > Thus it would similarly be:
typedef
CGAL::Regular_triangulation_euclidean_traits_3<K>
Traits;
typedef
Traits::Weighted_point
Weighted_point;
typedef CGAL::Triangulation_vertex_base_3<K>
Vb0;
typedef CGAL::Triangulation_vertex_base_with_info_3<int,
K, Vb0> Vb;
typedef CGAL::Regular_triangulation_cell_base_3<K>
Cb;
typedef CGAL::Triangulation_data_structure_3<Vb,Cb>
Tds;
typedef
CGAL::Regular_triangulation_3<Traits, Tds>
Rt;
Rt rt; Rt::Vertex_handle vh = rt.insert(..)
vh->info() = my_id;
Weighted_point wp =
vh->point();
etc. Nevertheless, I can only advise you to switch to a much more
recent version so that you can benefit from the various
improvements. Best, On 18/06/2019 14:54, BRYang wrote: Hi, Mael. I am now using CGAL with version 4.8.2, and I find that Weighted_point_3 is not a member of 'CGAL::Epick', but a member of 'CGAL::Regular_triangulation_euclidean_traits_3'. Is there still an index associated to each of the vertices in the 4.8.2 version of CGAL? Or we can only fix this with a higher version of CGAL? Thank you! Best, Baorong Yang -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ |
- [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, BRYang, 06/18/2019
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, Mael, 06/18/2019
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, BRYang, 06/18/2019
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, BRYang, 06/20/2019
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, Sebastien Loriot (GeometryFactory), 06/20/2019
