cgal-discuss - Re: [cgal-discuss] Iteration over Voronoi faces
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] Iteration over Voronoi faces
  • Date: Wed, 19 Jun 2019 20:30:51 +0200 (CEST)
----- Le 19 Juin 19, à 3:16, Stefan Witzel
a écrit :
> Am Di., 18. Juni 2019 um 19:54 Uhr schrieb Monique Teillaud
>> ----- Le 18 Juin 19, à 12:06, Stefan Witzel
>> a écrit :
>> Yes of course, that was the starting point of the discussion. But I cannot
>> (easily) turn them into a closed path because the endpoints of the dual
>> segments don't match up.
>> Aren't you using the recommended kernels? they make sure that you don't
>> encounter arithmetic issues.
>> Even if you are using your own rounded arithmetics, then you _know_ by
>> definition that the two Voronoi vertices are the same. For this, it is
>> better
>> to rely on the combinatorics rather than arithmetic constructions.
> When I say "don't match up" I mean target() of one is not source() of
> the next (not because of imprecision but because they happen to lie in
> a region of the Poincaré disk where the cgal convention stipulates
> that the source() of one should be the source() of the next).
> What I take from this discussion is that hyperbolic segments are not
> useful and are not meant to represent edges of combinatorial polygons.
Hyperbolic segments are only useful to what the manual says. They are
standard geometric hyperbolic (non-oriented) segments, not combinatorial
objects.
> So to do things in the cgal spirit one should probably represent
> polygons by their vertices and only create the hyperbolic segments
> when drawing the polygon. In that situation one would then have the
> vertices as well as the segments available and could sort out the
> right orientation.
If I understand correctly, this goes along the same lines as what I proposed
in my previous email:
* use circulators to get the combinatorial structure (the polygon is left
implicit)
* use segments as (non-oriented) geometric objects.
> Just to make sure: this cgal convention on counterclockwise
> orientation of circular arcs is just an internal convention, not
> guaranteed behavior, correct? So if I have a hyperbolic segment I
> really know nothing about the role of source() and target()?
If I am not mistaken, source() and target() are not even mentioned in the
manual.
> Perhaps I should say this at least once (and it should probably have
> been earlier): it's great that cgal provides the power of computing
> hyperbolic Voronoi diagrams in such a robust way! I wouldn't have
> started the discussion if your software wasn't so useful.
We are glad that this new package can already be useful to some users!
Thank you for your comments.
Best,
Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
