Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram
- To:
- Subject: Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram
- Date: Tue, 2 Jul 2019 03:48:46 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Thank you, Mael.
I will have a try.
Best,
Baorong
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, BRYang, 07/02/2019
- Re: [cgal-discuss] Access the indices of vertices, edges and facets from power diagram, Mael, 07/02/2019
