cgal-discuss - Re: [cgal-discuss] Side effects
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] Side effects
  • Date: Thu, 4 Jul 2019 15:11:15 +0200 (CEST)
----- Le 25 Juin 19, à 11:55, Stefan Witzel
a écrit :
> Hi again,
> I am working with a Hyperbolic Delaunay triangulation, more specifically
> with a
> CGAL::Hyperbolic_Delaunay_triangulation_2<CGAL::Hyperbolic_Delaunay_triangulation_traits_2<>>
> dt
> Now I'm experiencing the following behavior: I have a program (and a
> set of input) that finishes "immediately" but if I add some code, it
> takes on the order of minutes and more *even in the old part of the
> code*. So clearly there is some side effect, and I'm pretty certain
> that I'm not producing it (the only thing I'm passing around is
> const). For all I can tell the output (of the old part of the code) is
> exactly the same as before so the side effect is restricted to
> runtime.
> So I'm wondering: is it possible that previous calculations performed
> with dt affect future calculations? I'm imagining something like if
> some calculation needed a certain precision (or number field), the
> consecutive calculations are performed with the same precision even
> though they might not need it.
Hi,
Might be, but honestly without a crystal ball that would tell me what yo are
doing, I cannot say more...
> If this is the case, is there a way to "reset" the precision?
I don't know much about Core number types, probably the Core manual says
something, see https://cs.nyu.edu/exact/core_pages/intro.html (however be
aware that the version that we maintain in CGAL is not the same as the native
Core)
> P.S.: In case someone has read the previous posts and is wondering: at
> the moment I can't get the circular kernel to work because I don't
> know how to turn a Hyperbolic_Voronoi_point_2 into a
> Hyperbolic_point_2.
I would recommend to have a quick look at the paper that we cite in the
Design and Implementation History section: Mikhail Bogdanov, Olivier
Devillers, and Monique Teillaud. Hyperbolic Delaunay complexes and Voronoi
diagrams made practical. Journal of Computational Geometry, 5:56–85, 2014.
http://hal.inria.fr/hal-00961390.
More details:
Hyperbolic_Voronoi_point_2 is the intersection of two circular arcs whose
centers are two Hyperbolic_point_2. So, the coordinates of a
Hyperbolic_Voronoi_point_2 lie in an extension field of degree 2, compared to
the coordinates of a Hyperbolic_point_2. That's precisely why we have two
types in CGAL.
So, if you are using rational input points with
CGAL::Hyperbolic_Delaunay_triangulation_CK_traits_2, you cannot convert
Hyperbolic_Voronoi_point_2 into Hyperbolic_point_2.
If you are using input points with algebraic coordinates and
CGAL::Hyperbolic_Delaunay_triangulation_traits_2, I guess that the two point
types are the same (to be checked in the code, they are probably both
Point_2<CORE::Expr>).
As mentioned in the manual, if you are just computing hyperbolic Delaunay
triangulations and Voronoi diagrams of point sites having rational
coordinates, then CGAL::Hyperbolic_Delaunay_triangulation_CK_traits_2 is
enough for you. If you are doing something that requires more tricky
computations on algebraic numbers, then you need the traits that you are
currently using.
Best,
Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
