- To:
- Subject: [cgal-discuss] facets in a regular triangulation
- Date: Mon, 8 Jul 2019 02:23:49 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
I have got a question. For a delaunay triangulation, a facet is incidental
to two cells which share the facet, so a facet in delaunay triangulation has
three vertices.
However, it shows that in a regular triangulation Rt, we can access four
vertices of a facet ffi as follows:
ffi->first->vertex(i)->point(), where ffi is a Finite_facets_iterator and i
\in {0,1,2,3}.
Does that mean that any three of the four vertices could generate
a face with the three vertices in regular triangulation?
- [cgal-discuss] facets in a regular triangulation, BRYang, 07/08/2019
- Re: [cgal-discuss] facets in a regular triangulation, Olivier Devillers, 07/08/2019
- Re: [cgal-discuss] facets in a regular triangulation, BRYang, 07/09/2019
