- To:
- Subject: [cgal-discuss] 3D mesh generation for skeletonization
- Date: Wed, 17 Jul 2019 12:17:48 +0900
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Dear experts,
I am tackling to mesh 3D image, and skeletonize the segments.
I currently use CGAL::make_mesh_3<C3t3> for meshing, and CGAL::extract_mean_curvature_flow_skeleton for skeletonization.
However, my data failed to be closed manifolds (in reality, the segments are closed entities) in the function, and therefore I failed to process the skeletonization due to the specification that mesh must not contain borders.
<https://github.com/CGAL/cgal/issues/3608>
I would appreciate it if you could tell me how to cope with such a situation.
Best regards,
Mitsuru Nishikawa
Best regards,
Mitsuru Nishikawa
- [cgal-discuss] 3D mesh generation for skeletonization, 西川満, 07/17/2019
- Re: [cgal-discuss] 3D mesh generation for skeletonization, Andreas Fabri, 07/17/2019
