- To:
- Subject: Re: [cgal-discuss] Viewer for Arrangement 2D
- Date: Tue, 30 Jul 2019 10:51:37 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
On Tuesday, July 30, 2019 9:29:10 AM CEST Guillaume Damiand wrote:
> Hello;
> The problem comes from CGAL::Kernel_traits, used to retrieve the kernel
> given the type of a Point.
> CGAL::Kernel_traits<Arr_circle_segment_traits_2<K>::Point_2>::Kernel is
> Dummy_kernel
> Is it a bug or is it normal ? I would like to obtain K.
That is strange. When `Kernel_traits` return `Dummy_kernel`, that means that
the type `Point_2` does not a nested `R` type. What is the kernel `K`, in
your
example?
Laurent Rineau, PhD
- [cgal-discuss] Viewer for Arrangement 2D, jasmeet.singh, 07/30/2019
- Re: [cgal-discuss] Viewer for Arrangement 2D, Guillaume Damiand, 07/30/2019
- Re: [cgal-discuss] Viewer for Arrangement 2D, Laurent Rineau (CGAL/GeometryFactory), 07/30/2019
- Re: [cgal-discuss] Viewer for Arrangement 2D, Mael, 07/30/2019
- Re: [cgal-discuss] Viewer for Arrangement 2D, Efi Fogel, 07/30/2019
