cgal-discuss - Re: [cgal-discuss] CGAL installation
  • To: "" <>, "" <>
  • Subject: Re: [cgal-discuss] CGAL installation
  • Date: Tue, 30 Jul 2019 17:58:52 +0000
  • Accept-language: en-CA, en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1;spf=pass smtp.mailfrom=usask.ca;dmarc=pass action=none header.from=usask.ca;dkim=pass header.d=usask.ca;arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=39MpJEDyV29ZRoZO8R9rZZ9Uwe9P4r+Pr2gTuI/ftyQ=; b=WrTkx0AXe5AY9OtpltuWbK5sWnnwHE2IGEIFpXUL6jt/JrBkDVOQgcveD0bQIQJCZMuxSGga3wWh/jVeqZFEZDAIMo/kYdzOV4OphTCz0KtQyELdztdwE8oZxHU4CFmJ9SAqz9AasZl7QaQGzfA1jQcrUkK3+sLyxwymWKr4y+EmARBOTt7Iy7aNQ1YzRzZc46IzqpMwG0dTqkSmQqI6VWQabyPYqDn9EpE00qZB04Px6eFX2pN7LL2kCyzSYLFmuBSomG9ycOSy57XHyT1KDO4vRfpiFqP4e0bf7eqcS5i1zxg7kzzXTCEe5jCrEUPMsUQE0y8cZyq1953GJMgE2Q==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=dq0X70ONYaI/2UIe8eTVvIWySZKefuqjcJ6J+bmXRiATtJYT0Ted9gtA0D411L+Edw0WCAag7THDi/nCoZgm/Wx+i8GYVc5jsA1Pi/mosJO/wW8gMNg2IHgpknxeYnCl6GM50vIiqB9BE2qg/89Iey94jWwwsl6GRtfmDSCl6VlFo900noPeZehaL5VKtyeXpFUg8yXyEvt9/xa/4cBQWhG7dWvdmcysG3JNcNJrz0Iholqp9no7gTXaVn60cSOYQedJbdDFpsXU1KsSI8yseIWZCjCivBYcDWFXAJTXM4HYdqDnHWgESwlMvgJGoKUPzDiu4f4worgmf7Gs1pUVXg==
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
I have attached 2 files that show writing a triangle to VTK. The idea extends naturally to multiple triangles, but it's easier to show how with this. I can provide more details if needed.
Hope this helps,
Cheers
Chris
Chris Marsh
PhD Candidate
chrismarsh.ca
On Tue, Jul 30, 2019 at 11:51 AM Shrabani Ghosh <> wrote:
Thank You, when you get time.
Can you tell me what file format this surface mesh takes as input?
#include <CGAL/Surface_mesh.h>
main(){
 Surface_mesh surface_mesh;
cmake_minimum_required (VERSION 3.11)
project (tri)
find_package(CGAL REQUIRED)
include(${CGAL_USE_FILE})
find_package(VTK REQUIRED HINTS
"/home/chris/Documents/PhD/code/CHM/cmake-build-release/lib/VTK/lib/cmake/vtk-8.1")
include(${VTK_USE_FILE})
include_directories(
${CGAL_INCLUDE_DIRS}
${CGAL_3RD_PARTY_INCLUDE_DIRS})
add_executable(main
main.cpp)
target_link_libraries(main ${CGAL_3RD_PARTY_LIBRARIES} ${VTK_LIBRARIES})
Attachment: main.cpp
Description: main.cpp
