cgal-discuss - [cgal-discuss] Cannot read my data file in off format
  • To:
  • Subject: [cgal-discuss] Cannot read my data file in off format
  • Date: Wed, 31 Jul 2019 12:32:11 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:wA4BhRD3uMg5v4EeNFdRUyQJP3N1i/DPJgcQr6AfoPdwSPv/osbcNUDSrc9gkEXOFd2Cra4d0ayH7uu5ADZIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfK1+IA+yoAjRucUanJZuJrgswRbVv3VEfPhby3l1LlyJhRb84cmw/J9n8ytOvv8q6tBNX6bncakmVLJUFDspPXw7683trhnDUBCA5mAAXWUMkxpHGBbK4RfnVZrsqCT6t+592C6HPc3qSL0/RDqv47t3RBLulSwKMSMy/mPKhcxqlK9VrhKvqQJ8zYDJb46aKPVwc7jBfd4YWWZNQtpdWzBfDo66coABD/ABPeFdr4TlulUOrQG+ChO3C+z1zD9Ih2L906w60+QmCgHG3BErEtUVsHTOt9r1Mr0eUe+1zKnP1jXDb/db1DPm5YjHdxAuu/CMXbZqfcXNzkkvEhrIg1ONooLrODOV0/4Cs2md7+d4U+KgkXUopBp1ojex3Msjlo7JhocTx1vZ9it52J44KcC8RUN/e9KpHphduzuZOoZ3WM8vQmBltSAnwbMco5G7ZjIFyJE/yh7fdfOHd4+I7wrlVOueOzt4gmhqd6mkiBa270es0PHzVs6x0FpSrypFlMfDtmwV2hDO7sWKTuFx80mi1DqV1A3e6/tILEE1mKbDLp4u2L8wlp4dsUTZGS/2nV37jLSMdko//Oik8evnYrXhpp+HN495jgXzP78hmsy6G+s4MwwOU3KH9uS70b3v5Vf5T6lSjv0qjqnZt4jXKtgUpqGjBw9Zy5ss6xekDzi6zdQYhmIHIUleeBOHiojpI0vBLOr5Dfe5mVSskS1ky+rIPr37Ud3xKS3In77lOLp88EVB0xEbzNZF5psSBKtSDuj0XxrKtMbRBBY/MkSbw+H8CJ0pzZkUXySAAqiCMPKDmVCN7+MrZeKLYdlG637GN/E56qu23jcCklgHcPzxhMZFWDWDBv1jZn6hTz/sj9MGSDpYuFZ4SuXgglmPFzVUYiTrBv5u1nQAEIujSLz7aMW1mrXYhXW0G5RXYiZNDVXeSS65JbXBYO8FbWepGuEklzUFUba7TIp4jEOhsQb7z/xsKe+GoSA=
Hi Users,
I am edge_collapse_surface_mesh to decimate triangles , I tried with few
data from cgal it works properly.
size 07338
Finished...
7338 edges removed.
999 final edges.
But when I am using one of my skull data which I converted from vtk to off
format using meshlab, in that case, the surface mesh can read the file but
cannot calculate even number of edges.
size 00
Finished...
0 edges removed.
0 final edges.
Which is that happening so? I have attached my file here.
Please suggest me how to fix the problem.
holes_tri.off
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/holes_tri.off>
