Re: [cgal-discuss] Error compiling refine fair example from polygon mesh processing
- To:
- Subject: Re: [cgal-discuss] Error compiling refine fair example from polygon mesh processing
- Date: Fri, 2 Aug 2019 07:54:00 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
This is a static assertion failing. Without looking at the code
I think it is because you are missing Eigen.
If you are using cmake add:
find_package(Eigen3 3.2.0 REQUIRED)
include( ${EIGEN3_USE_FILE} )
and see here how to configure it:
https://doc.cgal.org/latest/Manual/installation.html#title61
Sebastien.
On 8/1/19 10:33 PM, Shrabani Ghosh wrote:
I am trying to use the refine_fair_example
(https://doc.cgal.org/latest/Polygon_mesh_processing/index.html)
to compile but I am getting error something like below. Why I am getting
this error?
/home/sghos003/CGAL-4.13.1/include/CGAL/Polygon_mesh_processing/fair.h:143:5:
error: invalid application of ‘sizeof’ to incomplete type
‘boost::STATIC_ASSERTION_FAILURE<false>’
CGAL_static_assertion_msg(
CMakeFiles/executable.dir/build.make:62: recipe for target
'CMakeFiles/executable.dir/refine_fair_example.cpp.o' failed
make[2]: *** [CMakeFiles/executable.dir/refine_fair_example.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/executable.dir/all'
failed
make[1]: *** [CMakeFiles/executable.dir/all] Error 2
Makefile:94: recipe for target 'all' failed
make: *** [all] Error 2
- [cgal-discuss] Error compiling refine fair example from polygon mesh processing, Shrabani Ghosh, 08/01/2019
- Re: [cgal-discuss] Error compiling refine fair example from polygon mesh processing, Sebastien Loriot (GeometryFactory), 08/02/2019
- Re: [cgal-discuss] Error compiling refine fair example from polygon mesh processing, Shrabani Ghosh, 08/02/2019
