cgal-discuss - Re: [cgal-discuss] Poisson reconstruction of multiple connected components
  • To:
  • Subject: Re: [cgal-discuss] Poisson reconstruction of multiple connected components
  • Date: Wed, 7 Aug 2019 13:38:31 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thanks for your detailed explanation Simon.
This is indeed what I want do: identify as many inner points as there are
connected components.
Since there is an access to the underlying triangulation, the method you
proposed seems to be the way forward.
I will give it a try.
Thanks again for your help,
Gaetan
