- To:
- Subject: [cgal-discuss] fail in computing the power diagram from given spheres
- Date: Wed, 14 Aug 2019 11:29:13 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi, I am trying to compute the power diagram from some given spheres,
however, it will fail on almost all my datasets. I have tried removing the
spheres which are inside at least one other sphere from the sphere list,
however, it still fails. Can somebody help me with this?
The attached file is a sample of my dataset. each line represents a sphere
with its center and radius.
test_spheres.txt
<http://cgal-discuss.949826.n4.nabble.com/file/t375361/test_spheres.txt>
Thank you!
Best,
Baorong Yang
- [cgal-discuss] fail in computing the power diagram from given spheres, BRYang, 08/14/2019
