cgal-discuss - Re: [cgal-discuss] fail in computing the power diagram from given spheres
  • To:
  • Subject: Re: [cgal-discuss] fail in computing the power diagram from given spheres
  • Date: Mon, 2 Sep 2019 08:40:16 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Without seeing the code, I can only guess that you are not using
a Kernel with exact predicates.
Try using CGAL::Exact_predicates_inexact_constructions_kernel instead
of CGAL::Cartesian<double>/CGAL::Simple_cartesian<double>.
Sebastien.
On 8/14/19 6:29 PM, BRYang wrote:
Hi, I am trying to compute the power diagram from some given spheres,
however, it will fail on almost all my datasets. I have tried removing the
spheres which are inside at least one other sphere from the sphere list,
however, it still fails. Can somebody help me with this?
The attached file is a sample of my dataset. each line represents a sphere
with its center and radius.
test_spheres.txt
<http://cgal-discuss.949826.n4.nabble.com/file/t375361/test_spheres.txt>
Thank you!
Best,
Baorong Yang
  • Re: [cgal-discuss] fail in computing the power diagram from given spheres, Sebastien Loriot (GeometryFactory), 09/02/2019
