cgal-discuss - Re: [cgal-discuss] Skeleton: slight changes in number of nodes and edges
  • To:
  • Subject: Re: [cgal-discuss] Skeleton: slight changes in number of nodes and edges
  • Date: Fri, 6 Sep 2019 09:18:28 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Someone else already asked the question and I suspected the usage
of maps using address on simplices but did not find any after a
quick search.
It would need some more careful look at the details of the execution.
You can try to define CGAL_MCFSKEL_DEBUG and compare the output
on different runs, maybe you'll spot where things are not
deterministic.
Sebastien.
On 9/6/19 6:58 AM, Robert Sage wrote:
Hi I am running the Triangulated Surface Mesh Skeleton example below, and I notice that I get slightly different number of nodes and edges in each execution. Is that expected? And if so is there a way to arrange for identical results over separate runs - e.g. for unit tests?
https://doc.cgal.org/latest/Surface_mesh_skeletonization/Surface_mesh_skeletonization_2MCF_Skeleton_sm_example_8cpp-example.html
Thanks!
Robert
