cgal-discuss - Re: [cgal-discuss] Multi-domain mesh generation with sharp edges
  • To:
  • Subject: Re: [cgal-discuss] Multi-domain mesh generation with sharp edges
  • Date: Mon, 23 Sep 2019 13:21:42 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
You can see how it is used in this function:
https://github.com/CGAL/cgal/blob/master/Polygon_mesh_processing/test/Polygon_mesh_processing/pmp_do_intersect_test.cpp#L362
HTH,
Sebastien.
On 9/23/19 9:11 AM, imperin wrote:
Hello Sebastien,
Could you please show me an example how to use
Polygon_mesh_processing::intersecting_meshes() ?
Thanks a lot!
