cgal-discuss - Re: [cgal-discuss] refine_mesh_3 compile error after successful compilation and run with make_mesh_3
  • To:
  • Subject: Re: [cgal-discuss] refine_mesh_3 compile error after successful compilation and run with make_mesh_3
  • Date: Thu, 26 Sep 2019 14:09:24 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thank you so much! Sebastien!
I wrote the code myself, and created this error.
The example code compiles fine. So I made a word by word comparison and
finally found that my function call is wrong:
CGAL::refine_mesh_3<C3t3>(mesh.C3T3(), domain, criteria);
The "<C3t3>" should not be there!
Thanks again for the help!!!
Rundong
