cgal-discuss - Re: [cgal-discuss] How to read face_descriptor faces from file?
  • To:
  • Subject: Re: [cgal-discuss] How to read face_descriptor faces from file?
  • Date: Wed, 9 Oct 2019 17:29:13 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Using Polyhedron_3 you will need to either create a vector of Face_handle to get a mapping id -> face.
With Surface_mesh fd = 16 is working.
Sebastien.
On 10/9/19 5:16 PM, Shrabani Ghosh wrote:
Hi,
I have a file where all the faces are written. I want to read the file and
want to get the property_map value for that corresponding face.
Let's say, in file 16 2 is written.
If the value read from the file directly assigned to the face_descriptor fd,
it does not work.
face descriptor fd = 16 does not work.
without a boost_foreach loop is it possible to get face information?
