- To:
- Subject: [cgal-discuss] Problem with visibility polygon computation
- Date: Wed, 30 Oct 2019 02:19:01 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi all,
I'm using CGAL (v. 4.14-2) to compute the visibility region (polygon) within a simple polygon from one of its vertices, using the Simple_polygon_visibility_2 class.
On a particular combination of polygon/vertex, I'm getting the following assertion error:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: k+1<vertices.size()
File: /usr/include/CGAL/Simple_polygon_visibility_2.h
Line: 678
This occurs in the method scan_edges of the class Simple_polygon_visibility_2, it seems like there should be some intersection with the given segment/ray, but none was found.
When I run the same code with the class Triangular_expansion_visibility_2, it seems to work, giving the output:
regularized visibility region of q has 8 edges:
[7968/1 492/1 -> 7938/1 428/1]
[7884/1 408/1 -> 7968/1 492/1]
[8040/1 428/1 -> 7884/1 408/1]
[1318831/163 428/1 -> 8040/1 428/1]
[550099518/67867 31141784/67867 -> 1318831/163 428/1]
[8090/1 456/1 -> 550099518/67867 31141784/67867]
[7968/1 446/1 -> 8090/1 456/1]
[7938/1 428/1 -> 7968/1 446/1]
I'm attaching a minimal work example, together with the input file.
The input file has in each line the polygon vertex id, followed by its x- and-coordinates. The query point is the one with id 1716.
Could anyone help me with this issue?
Thank you all in advance.
# This is the CMake script for compiling a set of CGAL applications.
project( vis-poly )
cmake_minimum_required(VERSION 2.8.11)
set(CMAKE_CXX_STANDARD 14)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
# CGAL and its components
find_package( CGAL QUIET COMPONENTS )
if ( NOT CGAL_FOUND )
message(STATUS "This project requires the CGAL library, and will not be
compiled.")
return()
endif()
# Boost and its components
find_package( Boost REQUIRED )
if ( NOT Boost_FOUND )
message(STATUS "This project requires the Boost library, and will not be
compiled.")
return()
endif()
# include for local directory
# include for local package
# Creating entries for all C++ files with "main" routine
create_single_source_cgal_program( "vis_poly.cpp" )
#include <CGAL/Arr_naive_point_location.h> #include <CGAL/Arr_segment_traits_2.h> #include <CGAL/Arrangement_2.h> #include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include <CGAL/Polygon_2.h> #include <CGAL/Simple_polygon_visibility_2.h> #include <CGAL/Triangular_expansion_visibility_2.h> #include <fstream> #include <iostream> #include <string> #include <list> #include <vector> typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel; typedef Kernel::Point_2 Point_2; typedef Kernel::Segment_2 Segment_2; typedef CGAL::Polygon_2<Kernel, std::list<Point_2>> Polygon_2; typedef CGAL::Arr_segment_traits_2<Kernel> Traits_2; typedef CGAL::Arrangement_2<Traits_2> Arrangement_2; typedef Arrangement_2::Face_handle Face_handle; typedef Arrangement_2::Vertex_handle ArrVertex_handle; typedef Arrangement_2::Edge_const_iterator Edge_const_iterator; typedef Arrangement_2::Ccb_halfedge_circulator Ccb_halfedge_circulator; using namespace std; vector<Point_2> readInput() { vector<Point_2> Points; ifstream File; File.open("polygon"); string Line; long int Idx, XCoord, YCoord; while (getline(File, Line)) { istringstream Iss(Line); Iss >> Idx >> XCoord >> YCoord; Points.push_back({XCoord, YCoord}); } return Points; } int main() { // create environment std::vector<Segment_2> segments; Arrangement_2 env; Segment_2 CurrSegment; Polygon_2 AuxPoly; auto Points = readInput(); auto QueryPt = Points[0]; ArrVertex_handle CurrPtHandle = env.insert_in_face_interior(QueryPt, env.unbounded_face()); AuxPoly.push_back(Points[0]); ArrVertex_handle NextPtHandle = CurrPtHandle; ArrVertex_handle QueryPtHandle = CurrPtHandle; for (auto i = 1; i < Points.size(); ++i) { NextPtHandle = env.insert_in_face_interior(Points[i], env.unbounded_face()); CurrSegment = Segment_2(CurrPtHandle->point(), NextPtHandle->point()); env.insert_at_vertices(CurrSegment, CurrPtHandle, NextPtHandle); CurrPtHandle = NextPtHandle; AuxPoly.push_back(Points[i]); } assert(AuxPoly.is_simple()); CurrSegment = Segment_2(CurrPtHandle->point(), QueryPtHandle->point()); auto HalfEHandle = env.insert_at_vertices(CurrSegment, CurrPtHandle, QueryPtHandle); // compute non regularized visibility area // Define visibiliy object type that computes regularized visibility area typedef CGAL::Simple_polygon_visibility_2<Arrangement_2, CGAL::Tag_true> RSPV; // typedef CGAL::Triangular_expansion_visibility_2<Arrangement_2, CGAL::Tag_true> RSPV; Arrangement_2 regular_output; RSPV regular_visibility(env); regular_visibility.compute_visibility(QueryPtHandle->point(), HalfEHandle, regular_output); std::cout << "Regularized visibility region of q has " << regular_output.number_of_edges() << " edges:" << std::endl; for (Edge_const_iterator eit = regular_output.edges_begin(); eit != regular_output.edges_end(); ++eit) std::cout << "[" << eit->source()->point() << " -> " << eit->target()->point() << "]" << std::endl; return 0; }
polygon
Description: Binary data
- [cgal-discuss] Problem with visibility polygon computation, Natanael Ramos, 10/30/2019
