- To:
- Subject: Re: [cgal-discuss] How to load an OBJ into Polyhedron_3 ?
- Date: Wed, 20 Nov 2019 17:46:49 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 11/20/19 12:35 PM, leogarret wrote:
Hi,
Sorry, but I'm French
My question is : How to load an OBJ into Polyhedron_3 ?
Like here:
https://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2orient_polygon_soup_example_8cpp-example.html
but replace OFF_reader.h by OBJ_reader.h and read_OFF by read_OBJ
The call to orient_polygon_soup() is only needed if your input mesh
is not a valid surface mesh.
Sebastien.
Best regards,
Léo.
- [cgal-discuss] How to load an OBJ into Polyhedron_3 ?, leogarret, 11/20/2019
- Re: [cgal-discuss] How to load an OBJ into Polyhedron_3 ?, Sebastien Loriot (GeometryFactory), 11/20/2019
