- To:
- Subject: Re: [cgal-discuss] dependence question
- Date: Fri, 22 Nov 2019 12:17:57 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 11/22/19 11:50 AM, Andreas Fabri wrote:
Hello,
In a "standard installation" for the latest as well as previous releases of CGAL
the GMP and MPFR are used. You can switch it off with
cmake |-DCGAL_DISABLE_GMP=ON|
|Then there is a fallback to CGAL::Quotient<CGAL::MP_float> as exact number type.|
|The dependency on boost is strong, but limited to
some boost libraries.
See also:
https://doc.cgal.org/latest/Manual/thirdparty.html#title4
|Best,|
|Andreas
On 11/22/2019 10:46 AM, Gregory Soyez wrote:
Dear all,--
one of our codes uses CGAL 2D triangulation. I am struggling a little bit to figure out which of CGAL dependences are needed to build our code (for historical reasons we use autotools instead of CMake).
In practice, we include:
Exact_predicates_inexact_constructions_kernel.h
Delaunay_triangulation_2.h
Triangulation_hierarchy_2.h
Triangulation_vertex_base_with_info_2.h
At first sight, it seems that only the GMP library is needed for linking but the MPFR and Boost libraries are not needed. Can you confirm this is correct?
Is it still OK for an (installed) CGAL-5.0?
Many thanks in advance for the help,
Cheers,
Gregory
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] dependence question, Gregory Soyez, 11/22/2019
- Re: [cgal-discuss] dependence question, Andreas Fabri, 11/22/2019
- Re: [cgal-discuss] dependence question, Sebastien Loriot (GeometryFactory), 11/22/2019
