- To:
- Subject: Re: [cgal-discuss] remove multiple edges from 2D Arrangement
- Date: Sun, 24 Nov 2019 03:45:52 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
I'm not sure if an optimisation counts for adding to elegance.
If you keep track of the iter by a counter you can prevent starting
iteration from ->begin()
but from
it =arr->begin(),
it=+counter //(don't increment counter on deletes)
- [cgal-discuss] remove multiple edges from 2D Arrangement, gp, 11/23/2019
- Re: [cgal-discuss] remove multiple edges from 2D Arrangement, CarstenT, 11/24/2019
