cgal-discuss - Re: [cgal-discuss] GLPK Library
  • To:
  • Subject: Re: [cgal-discuss] GLPK Library
  • Date: Tue, 26 Nov 2019 15:20:30 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
To use this package, you need one of those library.
So you need to install one of them and reconfigure the example with
cmake.
Best,
Sebastien.
On 11/17/19 8:03 AM, Chaman Singh Verma wrote:
Hello
I am using CGAL-5.0 and trying to run /polyfit_example_without_input_planes
executable.
My machine is running on Ubuntu and I installed libglpk from the Ubuntu repository.
The cmake understands the path.
But, while running I get the following message:
This test requires either GLPK or SCIP.
What should I do?
Thanks
