- To:
- Subject: Re: [cgal-discuss] 3D mesh generation with interior surface.
- Date: Fri, 6 Dec 2019 08:31:27 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
From the c3t3, you can iterate facets in the complex using the range
[facets_in_complex_begin(), facets_in_complex_end())
https://doc.cgal.org/latest/Mesh_3/classMeshComplex__3InTriangulation__3.html
Sebastien.
On 12/2/19 3:13 AM, rdzhao wrote:
Hi there!
I'm working with 3d mesh generation with polyhedron mesh domain that has an
interior surface.
A similar example is provided in the tutorial:
https://doc.cgal.org/latest/Mesh_3/index.html#title23
But the tutorial didn't tell me how to find the surface after the generation
of the 3d triangulation. To be more specific, how can I find the interior
surface represented by triangles that exist in the generated 3d
triangulation?
Thank you so much for your help!
Rundong.
- [cgal-discuss] 3D mesh generation with interior surface., rdzhao, 12/02/2019
- Re: [cgal-discuss] 3D mesh generation with interior surface., Sebastien Loriot (GeometryFactory), 12/06/2019
