cgal-discuss - Re: [cgal-discuss] Question about Delaunay_triangulation_3.h
  • To:
  • Subject: Re: [cgal-discuss] Question about Delaunay_triangulation_3.h
  • Date: Sun, 5 Jan 2020 21:34:49 -0600 (CST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
I also tried to use a old version which is CGAL 4.11.3
Yet there was another error:
<http://cgal-discuss.949826.n4.nabble.com/file/t376165/1578281489%281%29.jpg>
Error C2499
“CGAL::internal::boost_::array_binary_tree_node<RandomAccessIterator,ID>::children_type::iterator”:
A class cannot be its own base class (sourcecode ThreeDimensionalShape.cpp)
QMAT_codes
C:\local\CGAL-4.11.3\include\CGAL\internal\boost\array_binary_tree.hpp 54
I then looked to the line 54:
<http://cgal-discuss.949826.n4.nabble.com/file/t376165/1578281632%281%29.jpg>
I wonder if this is due to the incompatible between boost and CGAL?
Thanks for your kind help and guidance~
Best,
Frank
be open, be creative, be critical
