- To:
- Subject: Re: [cgal-discuss] Advancing Front Surface Reconstruction with initial mesh
- Date: Mon, 27 Jan 2020 09:52:47 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I'm afraid it is not going to be possible. The AFSR package is using the
3D Delaunay triangulation as search space for possible triangles.
As your input mesh is most likely not a subset of a Delaunay
triangulation, it would first require a modification of the code
to handle the general triangulation type. Then the seeding would also
need to be modified as well as the candidate queue.
So it is a lot of modifications and theoretically it is not even
guaranteed that you could get a valid result without adding extra
points (in 3D constrained triangulation does not always exists).
I agree this is an interesting problem but I don't have a working
solution off the shelf.
Would dropping the island be a solution?
Sebastien.
On 1/26/20 3:43 PM, Florian Gawrilowicz wrote:
Hi,
Is it possible to use the “Advancing Front Surface Reconstruction” with an existing mesh and initialize the reconstruction with that, such that the (almost) all triangles of the initial mesh are contained in the triangulation.
Using the Hole Filling implementation does not work for me since:
1. There are many islands in the mesh
2. And points that are not part of a triangle
If possible a MWE would be extremely helpful, or details on how to modify one of the CGAL examples.
Thanks!
/F
- [cgal-discuss] Advancing Front Surface Reconstruction with initial mesh, Florian Gawrilowicz, 01/26/2020
- Re: [cgal-discuss] Advancing Front Surface Reconstruction with initial mesh, Sebastien Loriot (GeometryFactory), 01/27/2020
- Re: [cgal-discuss] Advancing Front Surface Reconstruction with initial mesh, Simon Giraudot, 01/27/2020
