cgal-discuss - Re: [cgal-discuss] Unknown CMake command “create_single_source_cgal_program”
  • To:
  • Subject: Re: [cgal-discuss] Unknown CMake command “create_single_source_cgal_program”
  • Date: Tue, 4 Feb 2020 09:47:49 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
I found it quite weird to see "-DCGAL_DIR=/cgal" on your cmake command, as installing cgal on a root directory is very unusual.
But judging from the error, you CGAL path seems to be "/home/botengu/cgal/". So I think using -DCGAL_DIR=~/cgal (or -DCGAL_DIR=/home/botengu/cgal if you prefer) should fix your problem.
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 04/02/2020 à 06:37, Godjenka a écrit :
I have been trying to install CGAL on Ubuntu through a VirtualBox for a
while, every time I run the command - cmake -DCMAKE_BUILD_TYPE=Debug
-DCGAL_DIR=/cgal - on an example, I get the following message(with no other
errors):
CMake Error at CMakeLists.txt:12 (create_single_source_cgal_program):
Unknown CMake command "create_single_source_cgal_program".
-- Configuring incomplete, errors occurred!
See also
"/home/botengu/cgal/Bounding_volumes/examples/Min_sphere_d/CMakeFiles/CMakeOutput.log".
I have seen the other similar topics on the page, they either differed a bit
or they weren't answered. I'd like anyone to help solve this problem.
