- To:
- Subject: Re: [cgal-discuss] using cgal AABB tree as class member
- Date: Tue, 4 Feb 2020 10:02:32 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
*intersections.hpp:
#include <vector>
#include <list>
#include <array>
#include <iterator>
#include <functional>
#include <memory>
#include <Eigen/Dense>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_triangle_primitive.h>
#ifndef INTERSECTIONS_HPP
#define INTERSECTIONS_HPP
using namespace std;
using namespace Eigen;
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
//typedef K::Ray_3 Ray;
typedef K::Line_3 Line;
typedef K::Point_3 Point;
typedef K::Plane_3 Plane;
typedef K::Segment_3 Segment;
typedef K::Triangle_3 Triangle;
typedef list<Triangle>::iterator Iterator;
typedef CGAL::AABB_triangle_primitive<K, Iterator> Primitive;
typedef CGAL::AABB_traits<K, Primitive> AABB_triangle_traits;
typedef CGAL::AABB_tree<AABB_triangle_traits> Tree;
typedef Tree::Primitive_id Primitive_id;
class Intersection {
bool exists;
Vector3d point;
Vector3d normal;
vector<Vector3d> triangle;
public:
Intersection (bool _exists, Vector3d _point, Vector3d _normal,
vector<Vector3d> _triangle);
bool Exists();
Vector3d Point();
Vector3d Normal();
vector<Vector3d> Triangle();
class AABBTree {
shared_ptr<Tree> tree;
public:
AABBTree (vector<array<double, 3>> & _points, vector<array<int,
3>> & _tris,
Vector3d & p0, Vector3d & p1);
Intersection getIntersection(Vector3d & p0, Vector3d & p1,
vector<Vector3d> & _lastIntersected);
*intersections.cpp
#include <vector>
#include <list>
#include <array>
#include <iterator>
#include <future>
#include <iostream>
#include <thread>
#include <limits>
#include <boost/optional.hpp>
#include "intersections.hpp"
typedef K::FT FT;
typedef K::Direction_3 Direction;
//typedef Tree::Intersection_and_primitive_id<Segment>
typedef
boost::optional<Tree::Intersection_and_primitive_id<Segment>::Type>
Segment_intersection;
//AABBTree::AABBTree(vector<array<array<double, 3>, 3>> & _scene){
AABBTree::AABBTree(vector<array<double, 3>> & _points,
vector<array<int, 3>> & _tris,
Vector3d & p0, Vector3d & p1){
vector<Point> points;
list<Triangle> triangles;
for (unsigned long int i=0; i < _points.size(); ++i){
points.push_back(Point(_points[i][0], _points[i][1],
_points[i][2]));
for (unsigned long int i=0; i < _tris.size(); ++i){
array<int, 3> _tri = _tris[i];
triangles.push_back( Triangle(points[_tri[0]], points[_tri[1]],
points[_tri[2]]) );
tree = make_shared<Tree>(triangles.begin(), triangles.end());
Triangle intersected;
Point closestPoint;
double closestDist = numeric_limits<double>::max();
bool intersectionFound = false;
Segment segment_query(Point(p0[0], p0[1], p0[2]), Point(p1[0], p1[1],
p1[2]));
list<Segment_intersection> intersections;
* //uncommenting this line causes the tree to return the correct
triangles when getIntersection is called later
* *//cout << tree->do_intersect(segment_query) << endl;*
Intersection::Intersection(bool _exists, Vector3d _point, Vector3d _normal,
vector<Vector3d> _triangle){
exists = _exists;
point = _point;
normal = _normal;
triangle = _triangle;
bool Intersection::Exists(){
return exists;
Vector3d Intersection::Point(){
return point;
Vector3d Intersection::Normal(){
return normal;
vector<Vector3d> Intersection::Triangle(){
return triangle;
Intersection AABBTree::getIntersection(Vector3d & p0, Vector3d & p1,
Triangle lastIntersected;
if(!_lastIntersected.empty()){
Point l0(_lastIntersected[0][0], _lastIntersected[0][1],
_lastIntersected[0][2]);
Point l1(_lastIntersected[1][0], _lastIntersected[1][1],
_lastIntersected[1][2]);
Point l2(_lastIntersected[2][0], _lastIntersected[2][1],
_lastIntersected[2][2]);
lastIntersected = Triangle(l0, l1, l2);
Point closestPoint;
p1[2]));
tree->all_intersections(segment_query, back_inserter(intersections));
for (auto it = intersections.begin(); it != intersections.end(); ++it){
Primitive pr = (*it)->second;
Triangle tr = pr.datum();
cout << "triangle points:" << endl;
cout << tr.vertex(0) << endl;
cout << tr.vertex(1) << endl;
cout << tr.vertex(2) << endl;
cout << "reference point" << endl;
cout << pr.reference_point() << endl;
if(boost::get<Point>(& (*it)->first )){
intersectionFound = true;
Point p = boost::get<Point>( (*it)->first );
double squaredDist = pow(p.x() - p0[0], 2) + pow(p.y() - p0[1],
2) + pow(p.z() - p0[2], 2);
if(squaredDist < closestDist){
closestDist = squaredDist;
intersected = tr;
closestPoint = p;
cout << "closest point: " << endl;
cout << closestPoint << endl;
//Intersection foo;
if(intersectionFound){
//double pt[3] = {closestPoint.x(), closestPoint.y(),
closestPoint.z()};
Vector3d pt(closestPoint.x(), closestPoint.y(), closestPoint.z());
Plane triPlane = intersected.supporting_plane();
Vector3d triNormal(triPlane.orthogonal_vector().x(),
triPlane.orthogonal_vector().y(),
triPlane.orthogonal_vector().z());
if(triNormal.dot(p0 - pt) < 0){
Plane reversed = triPlane.opposite();
triNormal = Vector3d(reversed.orthogonal_vector().x(),
reversed.orthogonal_vector().y(),
reversed.orthogonal_vector().z());
triNormal.normalize();
//double normal[3] = {triNormal[0], triNormal[1], triNormal[2]};
Point v0 = intersected.vertex(0);
Point v1 = intersected.vertex(1);
Point v2 = intersected.vertex(2);
/*cout << "..." << endl;
cout << v0 << endl;
cout << v1 << endl;
cout << v2 << endl;*/
vector<Vector3d> face;
face.push_back(Vector3d(v0.x(), v0.y(), v0.z()));
face.push_back(Vector3d(v1.x(), v1.y(), v1.z()));
face.push_back(Vector3d(v2.x(), v2.y(), v2.z()));
Intersection intersection(true, pt, triNormal, face);
return intersection;
} else {
Vector3d pt(0.0,0.0,0.0);
Vector3d normal(0.0,0.0,0.0);
face.push_back(Vector3d(0.0, 0.0, 0.0));
Intersection intersection(false, pt, normal, face);
//return foo;
- [cgal-discuss] using cgal AABB tree as class member, myociss, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, Mael, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, myociss, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, Sebastien Loriot (GeometryFactory), 02/06/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, myociss, 02/07/2020
