- To:
- Cc: Shourya Shukla <>
- Subject: Re: [cgal-discuss] trying to open the CGAL viewer
- Date: Mon, 10 Feb 2020 09:28:59 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
After running `make` an executable should be available (called Triangulation_2 in the example). Just run it, if the `make` operation has been successful.
Hey everyone,
I am trying to open a CGAL "viewer" or a GUI so as to run some examples.
I have cloned the source code and have followed the instructions mentioned
in [1]. What exactly should I be expecting after I have executed the 'make'
command? Is there anyway to open a GUI for the same?
Thanks,
Shourya Shukla
[1]: https://github.com/CGAL/cgal/blob/master/INSTALL.md
- [cgal-discuss] trying to open the CGAL viewer, Shourya Shukla, 02/02/2020
- Re: [cgal-discuss] trying to open the CGAL viewer, Maxime Gimeno, 02/10/2020
