- To:
- Subject: Re: [cgal-discuss] Question about some topology models.
- Date: Wed, 12 Feb 2020 08:51:00 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I am doing some work with topology models like torus, eight models. I foundCGAL can read ,OFF files:
there are several models in our CGAL repo/data. I want to learn where can we
get such models for CG research purposes?
Many thanks in advance!
https://doc.cgal.org/latest/Polyhedron/Polyhedron_2draw_polyhedron_8cpp-example.html
If your 3D modell can be imported in blender, you can export it to X3D.
The X3D file can be read with the recent version 1.734 of white_dune
and exported to ,OFF with File -> export as .. -> ,OFF file
so long
MUFTI
- [cgal-discuss] Question about some topology models., Frank Dz, 02/12/2020
- Re: [cgal-discuss] Question about some topology models., J. Scheurich, 02/12/2020
- Re: [cgal-discuss] Question about some topology models., Marc Alexa, 02/12/2020
- Re: [cgal-discuss] Question about some topology models., Zhiyang Dou, 02/12/2020
