- To:
- Subject: Re: [cgal-discuss] Installing a CGAL GUI
- Date: Wed, 12 Feb 2020 11:04:50 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Ok, then check your Qt5 paths in cmake, it looks like at least one is missing or wrong. Also, check that in your configuration of CGAL you didn't uncheck "WITH_CGAL_Qt5", you actually need that for GUI applications.
Good point, I just realized, I had a message "NOTICE: This demo requires Qt5,
and will not be compiled."
Which is weird because I already had installed Qt5.
- [cgal-discuss] Installing a CGAL GUI, Godjenka, 02/10/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Andreas Fabri, 02/10/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Godjenka, 02/12/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Maxime Gimeno, 02/12/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Godjenka, 02/14/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Maxime Gimeno, 02/14/2020
- Re: [cgal-discuss] Installing a CGAL GUI, Godjenka, 02/24/2020
