- To: "" <>
- Subject: Re: [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP
- Date: Sat, 22 Feb 2020 23:08:19 +0000
- Accept-language: zh-CN, nl-NL, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Brilliant! It really helps me a lot! Btw, the Package you recommend is quite related to my work and I will dig into it later! Thanks!
On Feb 22, 2020, at 11:25 PM, Andreas Fabri <> wrote:
You could determine what primitives intersect in parallel with Epic and
OutputIterator CGAL::AABB_tree< Tr >::all_intersected_primitives ( const Query & query,
OutputIterator out
const https://doc.cgal.org/latest/AABB_tree/classCGAL_1_1AABB__tree.html#a9f40594599eded5f9a79f74186710697
and then in a sequential pass compute the intersections.
By the way, did you have a look at the slicer:
https://doc.cgal.org/latest/Polygon_mesh_processing/index.html#title52
Best,
Andreas
On 2/22/2020 11:12 PM, Yifang Zhao wrote:
But I need to compute the exact intersections between a plane and the polyhedron. That’s why I am using epec for aabbtree. Is there any solutions to do this? Or it is not possible yet?
Sent from my iPhone
On Feb 22, 2020, at 10:28 PM, Andreas Fabri <> wrote:
Epec is currently not multi-threading safe.
The AABB Tree does not need exact constructions, so we should think
about a way to use the points/triangles/planes for Epic, together with
the face handles of the Polyhedron parameterized with Epec.andreas
On 2/22/2020 9:55 PM, Yifang Zhao wrote:
I am using EPEC Kernel.
Sent from Mail for Windows 10
Sent: 2020年2月22日 21:54
To:
What kernel do you use?
On 2/22/2020 9:51 PM, Yifang Zhao wrote:
I have a for loop containing approximately 1,000,000 iterations of calling AABBTree.all_intersections() method. Thus, I use #pragma omp parallel for to speed up the program. However, I got an error as "A heap has been corrupted". The cpp file is roughly like the following:
Polyhedron polyhedron;
Facet_tree m_facet_tree(faces(m_polyhedron).first, faces(m_polyhedron).second, m_polyhedon);
for (int i = 0; i<100; ++i){
Plane plane = Plane(1, 0, 0, 0);
// Compute intersections
typedef std::vector<Facet_tree::Object_and_primitive_id> Intersections;
Intersections intersections;
m_facet_tree.all_intersections(plane, std::back_inserter(intersections));
Finally, The program will break here:}
~Handle()
if ( PTR && (--PTR->count == 0))
delete PTR;
What are the possible reasons that cause this problem? Thanks a lot!}
Kind Regards,
Yifang Zhao.
-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP, Yifang Zhao, 02/22/2020
- Re: [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP, Andreas Fabri, 02/22/2020
- RE: [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP, Yifang Zhao, 02/22/2020
- Re: [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP, Yifang Zhao, 02/22/2020
- Re: [cgal-discuss] Heap corruption when constructing AABB tree with OPENMP, Yifang Zhao, 02/23/2020
